dslogredux!!!??? HELP!!
Stretchss
Post by Stretchss »
i have u7193 v.9r08 and logged my data but cant download it on my computer to see it in dslogredux. i dont see an option on programmer to download it to pc. any help please? thank you!
Sean
RE: dslogredux!!!??? HELP!!
you need to use diablosport's DataViewer software to download it from the predator to your PC...
Stretchss
Post by Stretchss »
ok will try. thanks.
and once the log is in the Datviewer, you need to go to FILE > EXPORT TO CSV and save it as a csv file to your pc... then you open that csv file in dslogredux.
Stretchss
Post by Stretchss »
YEAH thanks got it. after i change the inj slope, do i need to run another log and also my afr is 14.75 and says it should be 12 to 13.
trucks an 03 silverado ss 6.0l. i did log at 64mph and 2000rpm temp is 37deg. also should i do anther when temp rises.
Stretchss
Post by Stretchss »
also i couldnt find the air fuel ratio in data on programmer
noooo...
the afr during normal part-throttle driving will always be 14.75.. that's what it's supposed to be...
the 12.6-12.8 AFR is for WOT... but - on your model predator for your older truck, you will not have the AFR parameter available on the predator to log, so I wouldn't adjust any WOT stuff... you'd have to log with a laptop and the dataviewer program to be able to have that available to log.
I would just make the slope adjustment now and leave it...
then when it warms up, do a new data log and re-adjust it if needed...
Stretchss
Post by Stretchss »
thanks for all the help. did another data log and it said to increase 3%. but wow the 1st adjustment was awesome. can feel the power and trucks computer said my fuel econ. went from 16mpg to almost 23mpg.
leave it man...
you can't do back to back logs like that...
after you flash a tune adjustment, you need to put on about 50 miles before you do another log... because the pcm has to relearn the fuel trims all over again and let them settle in...
you keep doing logs back to back, and you'll be chasing your tail all day long LOL
