Torque Management
chuckie311
RE: Re: RE: Torque Management
Post by chuckie311 »
hey mike another problem im having is when i set either the upshift rpm to 6000 or the upshift mph to 60 the truck does not shift where it suppose to and it stops at 5600 even after raising the redline by 1000
chuckie311
any progress on this yet....just checking for updates..
chuckie311
getting frustrated... i bought this over a month ago even paid 40 bucks for over night shipping..cant use it 1 because the torque management i cant disable and 2 when i tried to set it to shift and a higher rpm it will not shift at those points..can you give me a update on what you are finding out i mean i have a product sitting here collecting dust.if you cannot get this resolved within the next few weeks which i think is plenty of time i would like to return my product and just go get a custom tune!!!
n6oli
Post by n6oli »
I think "chuckie311" is talking about if you turn the torque managment setttings
too "on" and then you save the tune, and go back to the torque management settings again it shows them to be "off".
It should show what the status is when you go back to that screen. Not just default to off when their infact on.
Also its very annoying to me that in the modify parameters section if you change, let's say spark, then you go back to the main menu screen it always goes back to the top of the menu. Axle Ratio in my case U7198.
It should just go back to the spark line in the main menu, so you don't have to scroll all the way down again.
chuckie311
YAWN 2 months and yet no one from diablo will give me an update...you sure were fast to fire away your answers from the start but yet nothing now..what was once great customer service has now turned to nothing..still have my paper weight that dosent work correct at home..to me its 360 dollars wasted..Glad you cant help keep me update once a month or give me in progress on what you are finding..and no N6OLI im not talking about when you save the tune it keeps them at off you cant not change them at all.
bump
Return to “Predator GM Gas”
