2009 Tahoe z71 5.3L running rich
krom
Post by krom »
Hey gang,
New to the forum. I am thinking of purchasing a 7194 for my 09 Tahoe Z71 5.3L. I have a Flowmaster Series 50 SUV muffler and Volant CAI. The motor seems to be running rich now due to the CAI. Wondering if one of the tunes on the 7194 or a Diablew tune can help fix this. Thanks for your input.
RE: 2009 Tahoe z71 5.3L running rich
yes, it can be fixed by getting your fueling adjusted correctly...
and can also be fixed and more power gotten via a custom tune...
krom
Post by krom »
redfoxsa
Re: 2009 Tahoe z71 5.3L running rich
Post by redfoxsa »
krom wrote:Hey gang,
i have a same setup you have
i have a magnaflow cat back
after i install the volant CIA i feel like i lose some power and the motor seems unstable maybe running rich due to CAI.
i don't know what i have to do .
Regards
RE: Re: 2009 Tahoe z71 5.3L running rich
check the stickies and do some data logging, adjust your slope to get your fueling adjusted correctly so that your average ltft's are in the 0 to -2 range...
krom
Post by krom »
Hi Monte,
In another Q&A thread the member posted:
-- Can I make my own custom tunes (not just a modified tune)?
You said this is possible only if you are a dealer or authorized tuner with the software. I take it the exception is being able to adjust your injector slope so that you can bring the ltft's in range as you specify?
yes... that's considered a "modified tune"... you can modify the tune via the predator/trinity yourself...
a "custom tune" is done via the tuning software...
With the 7194 predator for your vehicle, you can do/adjust all of these things yourself, via the predator unit itself:
COT time delay
DoD disable
Idle RPM Drive/Neutral
Injector Slope adjustment
WOT Fuel 2k-3.8k / 4k-4.9k / 5k-7k
Rev Limit
WOT Spark (in degrees) 1k-3.8k / 4k-5k / 5.2k-7k
Fan adjustment, individual adjustment per temp dependent cell
Tire Size
Speed limit(truck/SUV only)
Clear codes supported
Live data and log supported
krom
Post by krom »
Yes. I found that list on the product page. In addition to that, what is the custom tune able to provide?
a custom tune, done by a diablosport CMR tuner such as myself, adjusts a lot more parameters that the end-user doesn't have available via the predator/trinity handheld unit...
the CMR tuning software is like hp tuners, efi live, etc etc and allows access to EVERYTHING in a tune file...
the fueling and timing adjustments can be done more precisely, instead of just a general range like the handheld has you do...
torque management settings, knock retard settings, throttle settings, WOT/PE settings, AFR settings, fueling, timing, and a whole slew of other things...
krom
Post by krom »
Excellent. Thank you.
