wescollins wrote:Thanks, specifically I'm wondering what exactly you can do with the torque/abuse management (gm nannies). I guess there's an engine TM and a tranny TM, delays, etc.
http://www.diablosport.com/index.php?mo ... lay&pid=98
If you look there, it tells you about torque management, and imply's that you can input certain percentages, etc. I was thinking you did that through the TCM.
What exactly is NOT adjustable, that would be adjustable with TCM adjustments? Thanks!
and it also states that not all options are available on all model predators...
those tranny options are for older vehicles, other model predators...
the vehicles that the tranny stuff is available on, are older and have a single PCM (powertrain control module) that controls both the engine and the tranny settings... so that's why those vehicles have access to the tranny settings.
newer vehicles, like yours, mine, basically any newer GM vehicle from model year 2006.5 and newer - do NOT have a single PCM for both the engine and tranny... they have individual modules...
there are separate modules... an ECM (for the engine) and a TCM (for the tranny)...
and at this point in time, there is no TCM support, so you can not adjust any tranny settings.
but, if there WAS tcm/tranny support (but there isn't for you), you'd be able to adjust the shift points, shift speed, shift pressure/firmness, TM, etc etc.
hope that clears it up for ya...
