Trinity Can Not Tune My CAR ( Tahoe 2010 )
Dear Sir,
I just Received my Trinity 2 Days ago ....
First Thing i do after i install the DSdownloader to my PC
i update my Trinity With :-
trinity_1r07.crom
Then
trinity_u7194-1r07a_update.crom
As instruction , Now i abel to Tune my Vehicle ( 2010 Chevy Truck )
But i did Not found any other vehicle only Comoro on Chevrolet 2010
and after i ask ( 06MonteSS ) they told me to choice 2009 Tahoe from the Trinity
i Do , but i still can not Do any Performance Tune on my car
i only abel to use Monitor and Diagnostic
- when i log in to the performance i got message :
( Modify stock tune allows you to change parameter, such as speed limit,
without adding power or torque.)
then
( your calibration is not currently supported. Trinity will try to save your
original backup. press enter to view CALID.)
note : after i chose tahoe from 2009 menu , the trinity show not they support
corvet c6 ,,,,, and after that trinity restart )
waiting for technical support replay
Thanks and best regards
trinity_1r07.crom
Then
then
RE: Trinity Can Not Tune My CAR ( Tahoe 2010 )
you need to let it save a copy of your original backup stock tune file...
then export that original backup tune file from the trinity to your PC...
then post that original backup tune file up here in the forum, and they will have to add support for your calibration ID...
or, you may need to get your ecm updated by your dealer to a newer calibration ID in order for it to recognize your vehicle and allow it to work.
here my Backup file
check attached file
- tahoe2010.grg
- Backup File
- (70.69 KiB) Downloaded 321 times
Re: RE: Trinity Can Not Tune My CAR ( Tahoe 2010 )
Thanks for your Reply06MonteSS wrote:you need to let it save a copy of your original backup stock tune file...
My Backup File
here my Last Backup File after i install Volant CAI on my Tahoe
Regards
5 april 2010
Regards
5 april 2010
- TAHOE.grg
- Tahoe 2010
- (70.69 KiB) Downloaded 244 times
RE: My Backup File
thanks.
Re: RE: My Backup File
Still Waitingmikel wrote:thanks.
RE: Re: RE: My Backup File
I ma told your vehicle is already supported in 1r07a.
Re: RE: Re: RE: My Backup File
No Sirmikel wrote:I ma told your vehicle is already supported in 1r07a.
Not supported
RE: Re: RE: Re: RE: My Backup File
Please go to options/change vehicle type/and reselect your vehicle, then see if it supports the truck again.
Re: RE: Re: RE: Re: RE: My Backup File
his whole initial issue was, that there's no 2010 Tahoe vehicle selection in there... so he had to select 2009 Tahoe...mikel wrote:Please go to options/change vehicle type/and reselect your vehicle, then see if it supports the truck again.
Exactly06MonteSS wrote:his whole initial issue was, that there's no 2010 Tahoe vehicle selection in there... so he had to select 2009 Tahoe...mikel wrote:Please go to options/change vehicle type/and reselect your vehicle, then see if it supports the truck again.
but MIKEL even when i select the Tahoe form 2009 i still can do any performance tune .
then
please try as I suggested just so we know for SURE.
Options/change vehicle type/2009/Chevy/1500/5.3
Then performance tune and see what it says.
Mikel i do that 10 times only message i got :mikel wrote:please try as I suggested just so we know for SURE.
then
and i upload my backup here
RE: Re: RE: Re: RE: Re: RE: My Backup File
OK, we're looking into it.
