87 octane tune
6gear
87 octane tune
Post by 6gear »
I just did and 87 octane tune on my 09 Silvy 5.3 so what all does that include? Does it kill my mph limit or set it to a different number? does it kill any torque management, firm up the shift, change max rpm? add any power?
09 Silverado RCSB 5.3, 4x4
99 Corvette, 6 gear
2000 Suzuki Hayabusa
2002 Honda Goldwing
RE: 87 octane tune
TM is reduced, timing and fueling are optimized. Adds about 15 rwhp/25 ftlbs
SPeed limiter can be disabled in the adjustable parameters.
6gear
RE: 87 octane tune
Post by 6gear »
So I need to plug my unit back in to disable the speed limiter? Where will I find this setting?
99 Corvette, 6 gear
2002 Honda Goldwing
RE: 87 octane tune
after you select the tune go to modify tune, modify parameters and select rev and speed limits. set the limiter to OFF and press ESC until it asks you if you want to reinstall the tune, choose yes.
6gear
RE: 87 octane tune
Post by 6gear »
THANK YOU
99 Corvette, 6 gear
2002 Honda Goldwing
pelicandivebomb
RE: 87 octane tune
Post by pelicandivebomb »
how much power is the 87 octane tune supposed to give a 6.0?
2008 Silverado vortecmax z71: vararam intake, jba headers, true duals with X-pipe and two Dynomax VT mufflers
Return to “Predator GM Gas”
