2001 f250 6.8L V10 cant disable speed limiter
mfullr01
Post by mfullr01 »
u7152 doesnt have any options to change any parameters
the main reason i purchased it was to get beter fuel milage and to disable the top speed limiter what do i need to get this done
2001 f250 4x4 6.8L V10
mfullr01
RE: 2001 f250 6.8L V10 cant disable speed limiter
Post by mfullr01 »
can i get a costom tune that will do that
what is the revision on the Predator?
mfullr01
Post by mfullr01 »
9R03 its brand new just bought it last week
mytruck has K&N cold air and magnaflow exhaust
mfullr01
Post by mfullr01 »
is there a k&N tune that would help me
SCGt94
Post by SCGt94 »
basically what i would do is log the truck with the predator and watch your LTFT, get a general percentage and add that to the maf curve and reload the tune. That will get your fuel dialed in. You should be able to disable the speed limiter right through the tool as well.
Don
2002 WS6
mfullr01
Post by mfullr01 »
when i try to modify the tune it tells me the are no changable parameters with this engine and transmition combination
mfullr01
Post by mfullr01 »
am i doing something wrong or will it not do what i want
do i need to get another brand of tuner
mfullr01
Post by mfullr01 »
ssredrino
Post by ssredrino »
mfullr01 i need your programmer if you are not happy with it lol
ssredrino
Post by ssredrino »
eightrac
Post by eightrac »
You don't want to remove that speed limiter as your two piece rear driveshaft isn't balanced past 90mph. It can whip if you go much faster than that and break.
mfullr01
Post by mfullr01 »
is there any updates thate will solve this problem
mfullr01
Post by mfullr01 »
where can i get a custom tune
mfullr01
Post by mfullr01 »
ok i pulled my camper this past weekend with my programer installed and i got worse gas millage with it i usualy get 10mpg now im getting 7.5 i thought i did a lot of research and got the best programer for my truck but im finding out i wasted $350 and im getting no help from here
Return to “Predator Ford Gas”
