Predator & Powerpuck stack real HP for 05
reb0957
Post by reb0957 »
What is the real maximum HP for an 05 Dodge with the Predator Powerpuck stack?
I do not believe the same stack for an 03 through 04 motor will make the same HP gains in an 05. I know for a fact the 03 standard outputs where way more responsive to certain products than were the HO motors.
This being said, have you dynoed a predator puck stack on an 05 and what were the numbers?
johan
RE: Predator & Powerpuck stack real HP for 05
Post by johan »
If i recall the 05's when we had them in here with the puck and extreme tune they made about 410hp and 730ft/lbs, this was on a 4x4 dually and we use a Superflow load bearing dyno, which will show less hp when compared to a dynojet inertia dyno.
I just got done with the 06-07 5.9L cummins today and the truck today made 434hp and 830ft/lbs stacked with the extreme RKL tune. This was also a 4x4 dually.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
reb0957
Post by reb0957 »
Johan,
What supporting mods did these trucks have?
Can you produce the graphs?
johan
Post by johan »
All trucks we test are mostly stock aside from sometimes air intakes.
I can produce graphs.
Diablosport INC
