2006 Charger Daytona 5.7 Trinity transmission mode Issue!!!!
luis_gts
Post by luis_gts »
Hell all,
I just bought the Trinity for my charger RT daytona 2006, i already download and updated it with the "trinity_1r07.crom" and also the "trinity_u7194-1r07a_update.crom" but when i try to go to the Transmission mode and change the shift point autostick or whatever option is in that menu, the Trinity Freeze!!!! Anything else with the trinity seems to be working.
Im a little dissapointed with this Trinity, due to i asked about the transmission support for this vehicule before buy it, and one the staff guys told me that 06 HEMI is completly supported, and now i can not have access!!!
Any idea? what can i do to fix it?
Luis
Kahler
RE: 2006 Charger Daytona 5.7 Trinity transmission mode Issue
Post by Kahler »
Sure, I had the freeze problem also. There is a download for it. DS will read this and get you hooked up. Its here in the forum somewhere. Keep us posted
luis_gts
Post by luis_gts »
what file did you download it? i really want to fix this problem!!
DS guys any advise?
Luis
slickfitz
Post by slickfitz »
I have the same problem in my 06 300c awd..some options work in the trans section..like shift firmness..but the rest freezes the screen
luis_gts
Post by luis_gts »
No answer yet!! please guys help!!!
we're on it.
luis_gts
Post by luis_gts »
It is Working!!! :D
I downloaded the very last version and now is working! no more freezing!! thank you very much guys! i will test the car this weekend and i will post my impressions. Thanks mike,
Two more questions, what is the MODE 1 and MODE 2 in the autostick menu? and also how can i remove the speed limiter?
Luis
mode 1 and 2 are different methods of disabling the suto upshift, one or the other should work for you.
slickfitz
Post by slickfitz »
which version did you download..cuz I thought I had the latest one..and it's still not working..(freezing up transmission screen)
luis_gts
Post by luis_gts »
the one that says 04-21-10 is the second in the list, just below the tcm file.
try this one guys:
trinity-1t07ba_u7135.crom
(1.04 MiB) Downloaded 404 times
speedy00one
Post by speedy00one »
wow i was just about to post about this same problem and found this. Will this update work for all 5.7's as I have a magnum and my trinity is having the same issue when trying to make adjustments to any of the transmission selections?
Kahler
Post by Kahler »
I just stoped in to read some threads, and came accross this trans mode freeze issue. Glad the patch is avaiable to everyone. I willl say mikel the repair you sent me via e mail for the freeze problem worked well a few months as no problems with freeze.
batmancdb
freezing
Post by batmancdb »
Im still having this problem after i DL ath crom file please help
RE: freezing
reselect your vehicle in the options menu then try again please..
