I currently have a calid of vxcf4h2 on a 2006 F350. I have tried using your http://www.diablosport.com/downloads/pr ... _100hp.frg but i am unable to load a custom tune. The dealer has stated that there is another update for the computer in the truck and I am wondering if I should update it or not. The current programming keeps throwing low injector codes and since I am unable to use the custom tune, what shall I do? Do you guys support the latest fix from Ford? When is REV 18 coming out since right now I seem to be SOL.
DS
Update or Not
RE: Update or Not
That tune should work fine, but the next rev should be done in a week or two, and should have new tunes to address the low injector pressure codes.
RE: Update or Not
I'm sure that the tune IS fine BUT if you can't load it into your truck, what good is it? Can you send me a CROM file that I can load into the tuner? As I said before, I cannot load the custom tune.
Should I let Ford update the computer to the latest revision?
DS
DS
RE: Update or Not
What happens when you try to load the custom tune?
The Ford update will likely not change the situation, but 8r18 will.
RE: Update or Not
When I try to load a custom tune, the programmer always asks for the ignition to be turned on therefore not loading the custom tune. I have talked with customer help and still nothing. Waiting for 8R18.
DS
DS
RE: Update or Not
8r18 is going to be the solution to this issue.
I will email it to you as soon as possible.
