2004 Duramax - tranny slips in 85hp mode
str1249
Post by str1249 »
I have loaded all the different programs into my truck over time (I bought this unit in '05), and it has worked great in all modes up until recently.
Any time I use the 85hp program, the tranny slips like crazy, in "regular", "tow" or "no OD" mode. Any suggetions?
Is it possible some of the program in 85hp got damaged?
Is it possible to get the unit checked/reprogrammed?
rydnhi4x4
RE: 2004 Duramax - tranny slips in 85hp mode
Post by rydnhi4x4 »
Is the tranny slipping or is it going into limp mode?
http://www.thetruckstop.us
07 - CHEVY LBZ DURAMAX
All-Terrain T/A® KO - 295 75R16,
DYNOED ON 20 July 08 WITH -
PREDATOR SET ON THE 85HP TUNE / 423 RWHP - 709 FT/LBS
PREDATOR SET ON THE 120HP TUNE / 458 RWHP - 754 FT/LBS
FPSeth
Same issue
Post by FPSeth »
We have had the same issue on a customer's truck (2004 LB7) after the predator is installed on Towing, and he is towing anything (even an empty trailer), the tranny shifts irregularly and slips between gears. Take the program out and everything seems normal.
RE: Same issue
Are you letting it go through the relearn process?
Maxan
RE: Same issue
Post by Maxan »
I Have a Duramax LLY with Predator tuner at 85 HP and my transmission send P0735 and others at ecm.
Someone ask my problem?
Tigger
RE: Same issue
Post by Tigger »
I just got my predator back yesterday and loaded the 85 hp program. I was driving it back to work, about 180 miles and when I was almost there, I went to pass a truck. When I got on it, it limped. I got the P0700 code, and after I cleared it a few times it went away. But from what I can tell from other guys I know, it will limp alot easier now that it has happened.
I backed down to the 65 hp tune now in hopes that it will help.
RE: Same issue
how many miles on the truck?
Tigger
RE: Same issue
Post by Tigger »
My truck has 110k on it.
RE: Same issue
may want to look into freshening the tranny, new fluid/filter.
Maxan
Re: RE: Same issue
Post by Maxan »
mikel wrote:may want to look into freshening the tranny, new fluid/filter.
Transmission oil and 2 filter are changed, clutch test and oil pressure test and its all OK. Silverado 2004.5, Predator U7185, rev.2.02. Excuse my english! :evil:
