U7142
U7142
I've never flashed an onboard computer chip. I just want to make sure that I did this right. I installed the Performance Tune for stock or mildly modified 2004 Corbra SVTs. This was over the original, stock tune. Afterwards, the light on the Trac Control button was unlit until I pressed the button, just like it was prior to the flash. Following the instruction for such a problem, I modified the tune by turning the default Trac Control "on" and reflashed. Now the light stays on until the button is pushed. I just want to confirm that the Trac Control light being on still means that it is off as it did before the retune.
RE: U7142
Sounds like you figured it out perfectly.
Let us know if you need anything else.
