extreme power puck/trinity stack
Post your Cummins related Trinity questions here.
sawtooth
Post by sawtooth »
Whats the difference in running the trinity on the extreme tune 160hp while towing or having a power puck stack with the trinity on tow 60hp and the extreme power puck turned up all the way to 100hp for a total of 160hp again?
fixmedaily
Re: extreme power puck/trinity stack
Post by fixmedaily »
sawtooth wrote:Whats the difference in running the trinity on the extreme tune 160hp while towing or having a power puck stack with the trinity on tow 60hp and the extreme power puck turned up all the way to 100hp for a total of 160hp again?
My trinity warns not to tow on extreme tune.
fixmedaily
The issue is EGT....if you are monitoring it, you can see what works for you, but if you do not know your EGT, you should not go any higher than the tow tune when pulling more than 8K pounds.
3-DRacing
Post by 3-DRacing »
I don't have the puck but my egt's rise quickly when you get in it unloaded on extreme. Unless the puck helps cool them down I wouldn't want to tow anything on that setting.
Return to “Trinity Dodge Diesel”
