Truck has thrown error codes twice that the trinity says NO ERROR CODES PRESENT. Yet when I say clear error codes it does clear it.
Diablo Trinity part u7130 V.1r07
2005 Dodge Ram 2500 cummins diesel
Trinty won't read error code
RE: Trinty won
I've had exactly the same issue. I never noticed this with earlier versions.
RE: Trinty won
we'll have to check that out.
can you guys post your trucks calid and the revision on your trinity?
Info Requested
The revision is u7130 V.1r07 dated 01-11-2010 and it is set to the Performance Tune. The truck is a 2005 Dodge Ram, the same as fixmedaily.
fixmedaily
Re: Info Requested
I did find a post that said if you turn the key on and off three times the odometer will show you the error codes.David48 wrote:The revision is u7130 V.1r07 dated 01-11-2010 and it is set to the Performance Tune. The truck is a 2005 Dodge Ram, the same as fixmedaily.
RE: Re: Info Requested
can you guys post your calibration IDs?
fixmedaily
Re: RE: Re: Info Requested
Sure: where and how do I get it from?mikel wrote:can you guys post your calibration IDs?
RE: Re: RE: Re: Info Requested
options/troubleshooting/show calid
