Diablosport Trinity used with a non computer controlled WGA
xounlistedxox
Post by xounlistedxox »
I just ordered a Diablosport Trinity T-1000
It will be for tuning my 05 Dodge SRT-4
Currently I'm running an AGP Wastegate Actuator that is not computer controlled. Will the DST be compatible with this, or will I be better off going back to the factory wastegate?
I plan on doing some other mods in the near future including FIC 825cc injectors, bottle neck fix, ported exhaust manifold, stiffer wga spring, 100% e85, wideband etc, so the question carries on into these modifications as well.
Thanks in advance
RE: Diablosport Trinity used with a non computer controlled
As I recall, the factory gate is the better option, but I'd contact one of the CMR SRT4 pros and check with them, as they can make either set up work.
gizmodo
Post by gizmodo »
Put the stock WGA back on and skip the spring upgrade. Return all lines to factory and let the PCM control the boost. You will definitely need a CMR tune for what you're planning on running.
