2010 Support added!!
adonis123
RE: Re: RE: HEEEELPP WITH MY TRUCKSS!!
Post by adonis123 »
LOL I GOT IT TO WORK!!!!!!!!!!!!! I just changed the Com to 13 instead of there and it worked! now my last question is...should the check engine light stay turned on while on diablo tune? I currently have it running on 87 Octane gas. Is this the problem?
thats normal during the flash process.
adonis123
Post by adonis123 »
Thank you guys! you have been great! F superchips! I like your customer support better! ima buy me one for my challenger now!
adonis123
Post by adonis123 »
one last question, when starting the engine, is it normal for the starter to try to turn the engine one for a couple of seconds more than normal? For example, without a predator program you turn the ignition on and it starts quickly, but after you install the program its as if you keep igniting it for three seconds before it even starts.
thanks,
No, but that is fixed inthe latest revision, I am sending it now.
adonis123
Post by adonis123 »
ok thanks ! please disregard the email I just sent you!
dwebster
Post by dwebster »
Major newbie here. I have a Predator U7194 for my 2010 Camaro SS with cold air intake and Corsa exhaust.
How do I download the update U7194-9r15.crom to my Predator? Do I need it? Is it applicable to me?
Also the DS Downloader Installer. How do I do that?
I have the usb cable to hook to laptop but have never hooked it up. I have only done the preloaded tune.
I also have a disk that came with the product, I have never used that either. What is that for?
I feel like I am not using the Predator to its full potential.
Please help me get the most out of my Predator and my Camaro!
if your predator is working fine on your car now, there is no reason to update it... the newer revision updates were just to add support for additional vehicles...
so, if yours is working fine and you have no problems with it... you don't have to update...
if it ain't broke, don't fix it ;)
BobGreenTX
Post by BobGreenTX »
I purchased the Trinity 1000 and a connector was bad when I tried to hock it up. They fixed the connector but I think it might have blown the fuse that supports the interface. I have a 2010 Camaro 2SS/RS with the LS3 motor. Does anyone know which fuse could be stopping the T-1000 from getting power when I hock it up to the car. Diablesport has tested the T-1000 and it works Ok so it must be the car.
2010 Camaro 2ss/rs 6 sp m
Check the cig lighter fuse, or check the manual for which fuse controls the OBDII port (or ALDL connector)
Return to “Predator GM Gas”
