06 power puck
christengdin
06 power puck
i have a 06 power puck for a dodge 5.9 inline six motor and i ordered a new toggle switch from you guys the problem is the guy i bought the programmer from cut the wire at the switch so i am wondering witch wires go were on the switch it has a brown a white and a green wire that goes to the switch thanks for the time chris
christengdin
RE: 06 power puck
it would be nice if you guys would respond to emails or anything or answer your phones i didnt have any problems getting through to spend my money ordering parts but cant seem to get a answer on a supid question what wires go where so i can hook this thing up to my truck
RE: 06 power puck
Sorry, did not catch the initial post....
Doesn't the switch just plug into the puck?
christengdin
RE: 06 power puck
you know i see why nobody wants to buy this junk you guys are selling and they should hire some new techs as well you obviously didnt even read the goddamn post that is attached to this the dumbASS cut the plugend off of the unit i need to know what wires go where so i can hook it up to a switch weather its your switch or a aftermarket one
christengdin
RE: 06 power puck
good to see you guys are right on with keeping up with these posts techs, hu what a joke they should call you guys tanks cause all youre doing is sinking i tell you what i will just take this thing and throw it away cause all it is good for is tunning up your garbage can thanks for nothing a pissed off customer
RE: 06 power puck
So, its our fault the customer cut the harness?
The harnesses have changed many times over the course of production, so I cant just tell you what wire goes where.
And again, the harness he cut should still be plugged into the unit, so if you order a new switch from us, it should plug right inand relace the loose, cut wires you have now.
If I still dont get it, maybe you should post a pic of what you are trying to explain.
christengdin
RE: 06 power puck
yeah it wont unplug from the unit all those wires run together into the puck it was cut right at the little plug that comes in at the switch and i dont have the old switch or the little plug that goes into the switch and i did buy a new switch from you guys and i cant use it cause it needs to have that littel plug on the end of the wire to plug it into the switch there is only three wires that go to that switch i have tryed just splicing them together in different combonations and it does not seem to make a differance in power at least i can not feel any differance
RE: 06 power puck
This is a tough one....since like I say, the wire locations and colors have changed many times throughout production...
christengdin
RE: 06 power puck
so would anyone know where to go from here as far as you guys??????
Does this help?
- Puck Switch.JPG (39.51 KiB) Viewed 8017 times
christengdin
