Would you happen to have a base ori or frg file, in order to tune Box Code W3Z3? (This engine (4.6L DOHC), wiring harness, and PCM was originally installled in a 1993-94 Lincoln.)
Please let me know, or email it to me at: [email protected], if you have something we could use to make a good CMR tune for this application.
Thanks for your time!
Tom
Box Code W3Z3
RE: Box Code W3Z3
Cant find anything for that box code....
illinoisdyno
RE: Box Code W3Z3
Mike,
If I go to the CMR support section, it pulls up 2 different frg files for this box code: W3Z3RS.frg and W3Z3dia.frg. Either of these would work, although I cannot locate a template/cal id file...
Tom
Tom
RE: Box Code W3Z3
Hmmm...opened up for me, it had to download the template.
Did you click through the errors when it said no tpl available, cause it should try to d/l it after that, did for me.
I emailed you the .tpl file. I dont see any ori....
