I have a two wheel drive 2008 silverado with aftermarket tires and wheels.
What is the best solution to kill the TPS system warings due to not having moniters in the new wheel/tire setup?
I am also seeing Brake and ABS warnings. I beleive this is due to back tires being of larger diameter. Will I be able to resolve this issue with a diablo product.
I also have 2 corvettes with skip shift a '99 and '09 FRCs. Will I be able to turn off the skip shift function.
I know I can only have a tune on one vehicle at a time. Are these changes each considered part of a tune and revert back to normal when the diablo is placed on another vehicle.
Thanks in advance for any advice or recommendations
Tire Pressure, Brake, ABS and 1-4 Skip Shift
missedherbill
RE: Tire Pressure, Brake, ABS and 1-4 Skip Shift
TPMS can not be disabled inthe tune.
Brake and ABS shoud be fixed by correcting the tire size with the tune.
Skip shift can be disabled in any 6 speed applications.
