what would cause this?????
hoztile_killaz
Post by hoztile_killaz »
U7137 CROM 07 ON A 2009 DODGE HEMI 5.7 4X4 WITH REMOTE START.
RUNNING THE 91 OCTANE TUNE WITH NO MODIFICATIONS EXCEPT FOR THE TIRE ADJUSTMENT WHICH I SWITCHED UP TO THE 35'S :?:
WHEN I FIRE THE TRUCK UP IN THE MORNIN FROM IN THE CAB IT HAS A HARD TIME STARTING LIKE ITS MISFIRING OR SOMETHING..
ALSO THIS MORNIN ON THE WAY TO WORK I HIT THE THROTTLE AND THE ENGINE CUT OUT TWICE ON ME....
COULD THIS BE THE PROGRAMMER OR SOMETHIN ELSE ?
RE: what would cause this?????
Has it alwayas acted like this since you installed the tune?
hoztile_killaz
NO SIR JUST STARTED IT LAST WEEK
I WAS RUNNING THE 87 TUNE AND HAD NO PROBLEMS
I WANTED TO DO THE 91 TUNE TO SEE WHAT THE DIFF WAS IN PERFORMANCE
so, did it start with the 91 tune?
I need some more info here to try to help you...
hoztile_killaz
I HAVE BEEN RUNNING THE 91 TUNE FOR THE LAST 3 WEEKS AND IT JUST STARTED DOING THIS LAST WEEK LIKE MAYBE WED.
OK, this would indicate an issue with the truck.
hoztile_killaz
OK I WILL PUT THE STOCK TUNE BACK IN AND TAKE HER TO THE SERVICE DEPT.
THANKS MIKE
hoztile_killaz
Mike
i had the truck checked out at the dealer and of course they said nothing is wrong with it.
Do you think this might have something to do with the fuel system?
It only has a hard time starting the very 1st time i fire it up.
If i let it set for 2 days the RPMs fluctuate,jumps all the way up to 2g down to 1500 then to 1g and back up to 2g and then it finally
settles down to 1g and runs fine.
I have also noticed the tranny slippin when it shifts from 2nd to 3rd.
thanks
Do you get any codes?
hoztile_killaz
no sir
they didnt find any nor did the programmer
brandy16
Post by brandy16 »
There is a check valve in the fuel line that maintains the injector pressure when the car is not running. If this valve is leaking pressure back to the gas tank you will get these symptoms. Try turning the ignition on and waiting for a few seconds before you start the truck. This gives the fuel pump time to get the pressure back up so the engine has enough fuel. If you still have the problem take it to the dealer and ask them to check the fuel rail pressure after the car has sat over night. The fuel system losing pressure will not throw a code so don't let them B.S you make them check the fuel pressure. This happened to me and it took awhile for me to run the problem down and get the dealer to fix it. They kept telling me the same thing there's nothing wrong.
Kahler
Post by Kahler »
Brandy16 what motor is yours. ? What fuel presure did you have and what was it supposed to be ? at the fuel rail.
As fuel trims are changed in canned tunes,(from stock) I think they are. Wonder if that change in presure along with the tune, would that make a motor run worse ? or loose power, have less power. Dont mean to hijack thread, but im wondering......
hoztile_killaz
thanks for the info brandy i will try it tomorrow morning
if it still does it i will take it back to the dealership again
brandy16
Post by brandy16 »
The pressure will not change with the tune. So try what I told you ( leave the key on for a few moments and then start) and if the truck starts and dose not die or surge then put the stock tune back in and take it to the dealer.
hoztile_killaz
Just wanted to let everyone know that the dealer found the problem
it was the fuel pump.
sounds like this might be a problem for alot of 2009s
just wanted to share the info
