Incompatible hardware (no serial flash found) error
NHChalnga
Post by NHChalnga »
I'm trying to load the u7135-9r23.crom file to my Predator and receive an error stating "Incompatible hardware (no serial flash found) Contact tech support" error as the upload to the Predator completes.
I can successfully load the 9r12 crom so I'm guessing that my Predator does not have enough memory to load the 9r23 file.
My car is a 2009 Challenger SRT8. The calib code is 63004308AG which I'm hoping is supported in 9r23, but I have not found anything to definitively say one way or another.
If 63004308AG is supported, what's the work around for not being able to load the full 9r23 file?
RE: Incompatible hardware (no serial flash found) error
email sent.
NHChalnga
Post by NHChalnga »
Thanks for the quick response Mike. It worked perfectly.
flo1
Post by flo1 »
Hi Mike,
got a simlar problem with the "unable to store CROM file" appearing on display when trying to update to r23.
r12 workes fine but doesn't support 2010 SRT.
I think i do need the same file as NHChalnga...
BR
Flo
sent...
flo1
Post by flo1 »
wilson_gau
Post by wilson_gau »
I have same problem. I just get a used Predator. After I upload u7135-9r23.crom file, it shows the message "Incompatible hardware. (No serial flash found). Contact tech support (561) 908-0040 x1 www.DiabloSport.com"
email sent
wilson_gau
I updated using the file you sent me and it says:
"Predator u7135 does not support
Calid: 05094680AH
Too, update might be available"
Is that normal or I need other file?
Re: RE: Incompatible hardware (no serial flash found) error
wilson_gau wrote:I updated using the file you sent me and it says:
Calid: 05094680AH
what year is your vehicle?
if it is older than09, use 9r12.
wilson_gau
Calid: 05094680AH
06. Do I need the latest update?
Is the update is the problem or the device? Since before I plug it to my car, the error code already displayed.
gogreen1919
RE: Re: RE: Incompatible hardware (no serial flash found) er
Post by gogreen1919 »
incompatible hardware
same thing but the downloader will not function anymore it had 9r12 i updated to the latest one 9r27 or whatever that one was and got that message now it will not take anyfile and will not recognize in the downloader with or without the auto-detect on
Zog
Re: Incompatible hardware (no serial flash found) error
Post by Zog »
Same issue, Mike. '09 Challenger R/T.
Thanks in advance!
NHChalnga wrote:I'm trying to load the u7135-9r23.crom file to my Predator and receive an error stating "Incompatible hardware (no serial flash found) Contact tech support" error as the upload to the Predator completes.
RE: Re: Incompatible hardware (no serial flash found) error
sent!
HowardCan
Post by HowardCan »
Hi Mike, new owner of a Pretador and trying to get it going before the car is put away for the winter.
Similar issue here in that I am trying to install the latest CROM (v.9r27 I believe) as the unit will only accept the r12 CROM.
09 Challenger R/T
