2010 Dodge RT Challenger (how to set for max power?)
mattwickam
Post by mattwickam »
I just picked up a new Diablo Sport for my 2010 Dodge RT Challenger. I wanted to know how set it for maximum HP Gain? I set it for a performance tune and cant really tell any difference in the performance.
FYI: I have the CAI from Mopar and the MBRP Cat Back Exhaust System.
Matt
RE: 2010 Dodge RT Challenger (how to set for max power?)
Talk to a CMR dealer. You can't do it. They'll need to get it on the dyno and adjust the settings with the CMR software.
mattwickam
It seemed easy to hook up and follow the directions...but no change. Thanks for your input!
mrreddog
Post by mrreddog »
i seen no change in my 2010 r/t challenger either..is it snake oil??
mr.busa
Post by mr.busa »
bighemitex
Post by bighemitex »
if diablo doesn't do anything then how does it make cars with big cams that cant run on stock tuning run? a programmer is not a silver bullet for performance, if you aren't running good gas or are getting knock it will pull power, maybe your engine was heatsoaked after the first run? maybe the temp in the shop rose killing your intake temp? there are tons of diablo tuned cars and trucks out there that are really fast and couldn't have got that way without the DSP, so saying it does nothing is not the truth. I can understand you are upset but before come on here and start saying that Diablo products don't work maybe you should see what the Diablo crew can do for you tomorrow. they might even be able to fix that custom tune or look at your logs to see if there is something that can be done.
2003 RCSB Hemi Ram - Stock 20s, U7137, AIRAID CAI, 180* Jet T-Stat, Black Magic E-Fan, 3 Inch Cutout, Hooker Aero Chamber Muffler, TMR Mod, NGK 5306 plugs, Taylor 8.2 thundervolt wires, Pacesetter Longtube Headers, Pacesetter ORY, magnaflow cat, Innovate LC-1,
Exactly, instead of making bogus comments, why don't you get it tuned right. Many of us have seen substantial gains, plus my truck can't run without it.
mr.busa
Post by mr.busa »
bighemitex
well the DS guys don't work weekends, so you will have to wait until tomorrow to get answers from the man directly. just make sure you explain to him exactly what's going on and they will do what they can to help you. after that code is taken car of they will probably ask you to reinstall the tune and do some datalogging to see what the issue is.
mr.busa
Post by mr.busa »
bighemitex
edit
mr.busa
Post by mr.busa »
mr.busa
Post by mr.busa »
