U7194, version V.9R11, Hardware: UNIV_REV2, BUS: CAN, BUS Test: Not Done.
I just tried to use this Predator SN: D0054E0 on my 2006 Z06. the screen prompt said your application is not supported at this time. The predator will try to save your stock tune. I decided to back out of the process at that point. Escaped from that screen and removed the tuner connection. Started the car and it ran fine.
Do I have the wrong unit? I bought this one used and was told the unit had been un married to the original purchaser car. I also updated to the latest software.
I did buy this car used from a Chevy dealer. Would the message indicate the stock tune has been modified?
Your Application not supported at this time
RE: Your Application not supported at this time
Please update to the latest revision, emailing it to you now.
I just updated from your file. Should this solve the problem or might I have a model that needs the power train software updated? My 2006 Z06 is 345 in the first build run in 2005.
Plug it in to find out....
