J35 Recall??
J35 Recall??
Will the extreme Power Puck work with the J35 recall from Chrysler on the 6.7 Turbo Cummins?
RE: J35 Recall??
What does this recall entail?
Re: RE: J35 Recall??
New program for the ECU.mikel wrote:What does this recall entail?
EMISSIONS RECALL J35
REPROGRAM ECM – REGENERATION STRATEGY
Dear: (Name)
Chrysler has determined that some 2007 through 2009 model year Dodge Ram 2500/3500 trucks
equipped with a 6.7L diesel engine may require reprogramming of the Engine Control Module (ECM).
The problem is... The ECM software program on your truck (VIN: xxxxxxxxxxxxxxxxx) may cause
illumination of the Malfunction Indicator Light (MIL) when no problem exists or
under certain conditions allow heavy sooting of the turbocharger, exhaust gas
recirculation valve and diesel particulate filter. Heavy sooting could damage
emissions components and result in increased emissions.
What your dealer
will do...
Chrysler will repair your vehicle free of charge (parts and labor). To do this,
your dealer will reprogram your vehicle’s ECM. The new software will eliminate
false illumination of the MIL and reduce the potential for exhaust soot
accumulation in your engine and emissions components. The work will take
about ½ hour to complete. However, additional time may be necessary depending
on service schedules.
What you must do... Simply contact your dealer right away to schedule a service appointment.
If you need help... If you have questions or concerns which your dealer is unable to resolve, please
contact Chrysler at 1-800-853-1403.
California
residents…
The State of California requires the completion of emission recall repairs
prior to vehicle registration renewal. Your dealer will provide you with a
Vehicle Emission Recall Proof of Correction Form after the recall service is
performed. Be sure to save this form since the California Department of Motor
Vehicles may require that you supply it as proof that the recall has been performed.
Please help us update our records by filling out the attached prepaid postcard, if any of the conditions listed on
the card apply to you or your vehicle. You may also update this information on the web at
CCCCCCCCCCCCCCCCCCCCCCCCCC
If you have already experienced this condition and have paid to have it repaired, you may send your original
receipts and/or other adequate proof of payment to the following address for reimbursement: Chrysler Recall
Customer Assistance, P.O. Box 21-8007, Auburn Hills, MI 48321-8007, Attention: Reimbursement.
In order to ensure your full protection under the emission warranty provisions, it is recommended that you
have your vehicle serviced as soon as possible. Failure to do so could legally be determined to be a lack of
proper maintenance of your vehicle. Further, without this repair, your vehicle may fail a state or local
emission inspection test.
We are sorry for any inconvenience but trust that you understand our interest in clean air. Thank you for
your attention to this important matter.
Customer Services Field Operations
Chrysler Group LLC
Notification Code J35
I have not had any complaints.
