My esp bas and abs lights are on all the time. just had a dyno done and the tech shut them off. It says in your manual that the first thing you come to in quick change. In mine it says Dyno mode and looks like it should do the same thing but i can not get it tosave and shut the lights off. just wondering if there is another way to turn off the lights and activate everything again. HELP!!!
2009 challenger rt 5.7
ESP OFF
RE: ESP OFF
Turn Dyno Mode OFF. That should do it. If it doesn't there may be a wheel sensor problem.
RE: ESP OFF
Did they do a custom tune?
If so, I bet the problem is inthe tune, can you post it up here?
RE: ESP OFF
The guy at the dyno did some tuning with it. When you go into the tunes it says there was a 91cai + quick parameters. I have tryed to turn off the dyno mode and nothing changes. Not sure how to post the tune on here??
