Reading Fuel pressure
Post your Cummins related Trinity questions here.
fixmedaily
Post by fixmedaily »
Help please:
Is there a PID for reading the Fuel pressure comming into the cp3 pump?
I have installed a AirDog lift pump and do not know what fuel pressure it is putting out. My Glowshift gauge is pegged at max and I do not believe it is working properly. Need to read the input fuel pressure from my trinity.
Speardog
Re: Reading Fuel pressure
Post by Speardog »
fixmedaily wrote:Help please:
I would like to know the same thing to so I don't have to get a fuel pressure gauge. I know that the Quadzilla Adrenaline (according to their website) is able to read normal fuel pressure sustained by the lift pump, but I don't know what signal it is picking up. There has to be a PID, I just don't know which one.
Jeff
CumminsDemon
RE: Re: Reading Fuel pressure
Post by CumminsDemon »
I believe the PID for HFP is the HPCR.....reads in MPa. 168MPa=27k PSI
2005 CTD trinity, 7" Short stacks, AFE CAI,Bladerunner,quadboostfooler,6''lift with XD MONSTERS wrap with NITTO Trailgrappler M/Tz. BACKED by a NADP BRX 800 series full billit race trans.
Speardog
Re: RE: Re: Reading Fuel pressure
Post by Speardog »
CumminsDemon wrote:I believe the PID for HFP is the HPCR.....reads in MPa. 168MPa=27k PSI
ithere is a "fuel pressure" pid that reads up to 27k. But that is rail pressure, not fuel pressure
CumminsDemon
ithere is a "fuel pressure" pid that reads up to 27k. But that is rail pressure, not fuel pressure[/quote]
Oh hes woundering about the low pressure fuel pump.....gott cha.
3-DRacing
Post by 3-DRacing »
Same thing I've been trying to figure out. Mine is a early 04 that had the lift pump on the fuel filter canister and was replaced under warranty with a in the tank pump, curious what it puts out. Would be nice to have the rail pressure read psi too.
if rail pressure reads in kpa, click on it in the logging menu, choose change display units, choose PSI, then save the layout.
danny3535
Post by danny3535 »
mikel wrote:if rail pressure reads in kpa, click on it in the logging menu, choose change display units, choose PSI, then save the layout.
You mean mpa.
That the rail pressure is read in factory and you cannot change it to psi! I tried and it said that wasn't any other options. It would be great to have in psi so you don't have to multiply your mpa reading by 145 every time.
'04 2500 4dr 4X4 6-speed: 35's, 2.5 leveling kit, Custom Cai, Air Dog II 165, Trinity,Extreme PP, 351vgt with Fleece controller, SB dd 3250 clutch.
correct.
Problem with displaying it in psi is the values are too large to fit onthe gauges...
Speardog
Post by Speardog »
You mean mpa.
Not sure if your truck is different, but mine reads rail pressure in psi. It was under the HPCR fuel pressure PID.
Return to “Trinity Dodge Diesel”
