u7194 wont work on escalade
I have my u7194 I had used on my 07 Denali and I tryed to install on my 09 Escalade ext and a message says vehicle not supported. The chart says u7194 is for a 09 Escalade...any reason why it wont work?
RE: u7194 wont work on escalade
u need to update the predator. the 7194 is right but the software aint. u can download it from this website but u gotta have a serial cable and power supply
yeah ^ ^ ^ ^
you need to update that predator to a newer revision in order for it to support the 2009...
ok I tried to update it and when it was almost done it stopped and a message said to much data or something and now it just says it needs a crom file to work. any ideas?
you can not use the newer, bigger crom revision updates on that older version 7194 predator...
check the ftp site here for revision 9r08 or 9r10 instead, and try one of those...
http://forum.dslogredux.com/index.php?topic=35.0
Monte..Mike emailed me the 9r10 and I dl it to the unit but when I hooked it up to my Escalade I didnt have the choices I had originally which were Diablo tune ..87 octane tune..ect..all it had was..modify stock tune and original backup..so I chose modify stock tune. It said downloading stock tune but I am not sure if it was put in. If I installed 9r10 ..does that sound right for the choices? Or should I have a choice of Diablo..87 octane...It seems to be running better so maybe it worked and needs more miles on it to work the best. Thanks for your help.
Looks like an older tool then.
How long have you owned it?
