I have the analog AFR working and now I need the option of the external pid so I can datalog the info...what do i need to do...a step by step explanation would be awsome...
Thanks in advance
Ross
2009 Jeep SRT8
External AFR PID...question
RE: External AFR PID...question
Are you asking about logging on the Trinity or DataViewer? For the Trinity just scroll all the way to the bottom of the PID list and you will see it there. For DataViewer make sure you have the latest version and it should show up.
IF you need to log with DataViewer; download the 3.3.0.3 version from the Download page.
http://diablosport.com/index.php?module ... ay&pid=153
Also, IF you have deleted any of Trinity's Analog Inputs; go into Analog Input Config on Trinity and Reset to Default. Then simply add your AFR input, scale and range mapping to Analog input 1 or 2 as needed. Don't delete any of Trinity's analog inputs as DV and Trinity get out of sync for live streaming/logging purposes.
YKPizzaGuy
Re: RE: External AFR PID...question
Thanks I'll give it a shot.jimb wrote:IF you need to log with DataViewer; download the 3.3.0.3 version from the Download page.
YKPizzaGuy
RE: Re: RE: External AFR PID...question
Nope still no go on the external afr on the DV. I can't even get the dropdown option to show up
What crom and DV version are you using? You also need DV to re-query the vehicle to get any Analog Config changes.l
YKPizzaGuy
Re: RE: Re: RE: External AFR PID...question
Im running DV 3.3.0.3jimb wrote:What crom and DV version are you using? You also need DV to re-query the vehicle to get any Analog Config changes.l
and the Trinity is v.1r07a
And just so I know were talking about the same thing how do i do the re-query....sorry if the questions sound dumb but after messing around getting the AFR to work I know its best to just ask every thing..
RE: Re: RE: Re: RE: External AFR PID...question
Click the 'query vehicle' button again.
With Trinity attached to your ECU; In DV do File->Re Query Vehicle Info (or the blue disc with "?" icon).
Then, do File->Real Time Data Mode (or the yellow lightning icon).
IF you still don't see EXTERNAL inputs appear; download a log from Your Trinity containing your AFR signal and post it here.
YKPizzaGuy
Rock & roll. I got it working. Thanks guys. Your the best.
