MIKE/JOHAN - Fuel trims perfect - excessive KR at WOT
nofinga911
Post by nofinga911 »
Fuel trims are perfect - but excessive KR at WOT ...maybe you can help out with a custom tune please
MyLog.zip
(94.13 KiB) Downloaded 187 times
RE: MIKE/JOHAN - Fuel trims perfect - excessive KR at WOT
hey guys, perhaps the same issue I had with my Monte, where the fuel wasn't coming in quick enough, soon enough?? so Johan created me that custom tune to make it go into PE a little sooner, to get more fuel quicker??
Can you see that in the logs, or are we guessing?
I did not think the trucks had those issues.
Johan is out of the office this week as he had a baby on Wednesday, so for the time being, I'd suggest pulling some timing with the Predator and make sure we are using top quality fuel.
yes, I can see it in his logs - I've been going through all kinds of logs for him... trims are good... WOT afr and o2 numbers look good, but he's getting a lot of kr....
as for the fix about the PE fueling coming in sooner, that's just a guess for what might help fix his problem... worked for me... :wink:
nofinga911
and also, I am using and always have used 93 octane gas. and I have been getting it from BP
for ha-ha's... run a couple tanks of Mobil 93 through it... 1/2 way through the second tank, do a log and let's see what it has for numbers...
nofinga911
ok im still having the same problem even with the new gas...maybe you guys could make me a custom tune like you did for O6MonteSS ...my latest WOT file is attached...
nofinga911-WOT-Log.zip
(46.59 KiB) Downloaded 187 times
yeah... his fuel trims are good, and WOT AFR is good at 12.6... but getting a lot of KR in the PE upper rpm range...
Is this an escalade? What year?
'07 Escalade...
nofinga911
06MonteSS wrote:'07 Escalade...
thank you Monte....correct 07' escalade
nofinga911
hey guys, any ideas? I can really use some help...
edv2122
Post by edv2122 »
I had a similiar problem with mine except I have a 06 vette and the Diablo 93 Octane tune. What I did recently was fill a tank 100% with Exxon/Mobile gas 93 octane and then I added a bottle of Lucas Octane Booster. It eliminated all of the knock. I am going to try my next tank with just the Exxon/Mobile gas and see if the knock stays away without the Octane Booster.
I am also going to get a couple bottles of GM Top Engine Cleaner to clean the engine from carbon build up which can cause knock. I'll let you know what I find that works besides the above. I am trying to get rid of the knock with out any additives to the gas. But for now I would try the Exxon/Mobile gas and the Lucas Octane Booster.
edv2122
Post by edv2122 »
Oh...I got the Lucas Octane Booster from Pep Boys so it should be widely avail. Let a half tank run through before you log again.
Return to “Predator GM Gas”
