You can now set a shift light (one LED, all LEDs or progressive) and set up to 16 gauge alarms per layout inthe Trinity.
If you want an LED to go off when your ECT gets above 220*, no prob.
Want the whole thing to light up like Christmas when your IATs go over 120*? No prob.
Want all the LEDs to light up progressively as you approach your shift RPM, done.
Enjoy.
New Features addded: Shift Lights/Guage Alarms
tech@diablosport.com
Starting in 1r04ykcummins wrote:which crom update are these new features in?
I don't see how to do this in the manual, where do I find instrictions to add the shift lights? I don't see anything in the manual about LED's either. Am I looking in the correct place.
'06' SRT-8
Airaid CAI; 180 T-Stat, SpartanMAX, CMR Tune
JBA Catback; ESP Disable, SLP Linelock
Innovate LC-1, Wavetrac LSD
R1 Drilled/Slotted Rotors
The instructions may not have been updated yet, but this sticky was intended to be a guide to tell you how to do it:
http://www.diablosport.com/index.php?na ... ic&t=15356
.To set up a shift light, create a layout or open one of our layouts (in logging) that has an RPM gauge in the display.
Click on the RPM gauge.
Select 'set shift light'.
Set the RPM you would like the shift light to activate, press enter.
You'll now select whether you want one (1) LED, all LEDs, or a progressive shift light.
Now, click record and your shift light will be activated.
If you close the layout, and save it, you can open it in monitoring and your Shift light will be there
