2010 Camaro SS L99 Kooks LT Header Tune
ukalumni93
I am getting ready to install Kooks Longtube heaters and HF Cats on my L99 Camaro. I have already installed an Airaid CAI , CB Cat back exhaust and running the Diablo Tune from the Predator I purchased. Any assistance would be greatly appreciated.
RE: 2010 Camaro SS L99 Kooks LT Header Tune
After the long tubes ae installed you will need to put maybe 50 to 100 miles on and then do a cruise log to see where the long term fuel trims are at. They will probably be somewhat positive (lean), then adjust the trims accordingly to achieve between 0 and -2. You also can expect to start throwing codes like cat efficiency and shifted lean accompanied by a CHECK ENGINE LIGHT. You'll need a tuner, someone like 06monteSS AKA Lew, to do a custom tune to permanently correct this issue.
ukalumni93
Thanks. I have a Predator Tuner. The code issue is what I am worried about. Will the lack of efficiency causing the codes damage my engine if I drive it? I mean beyond the 100 miles or so to log?
nope... won't hurt anything at all.. you'll just have to put up with seeing the CEL on the dash... heh
ukalumni93
Re: RE: 2010 Camaro SS L99 Kooks LT Header Tune
Urgggggh... the dreaded CEL.... 06monteSS- Would you mind putting a tune together to get rid of it for me? I saw on previous posts that it was requested for the original backup tune and the last written to be uploaded so I thought I would go ahead and load them up. I appreciate all your input. The header install is starting in just a few minutes. Tired of seeing them sitting in the living room. not doing me much good there.lol. Tool: U7194 v.9r15. Thanks.06MonteSS wrote:nope... won't hurt anything at all.. you'll just have to put up with seeing the CEL on the dash... heh
- Original Backup.grg
- (67.94 KiB) Downloaded 309 times
- custom_tuneLastWritten5212010.grg
- (4.25 KiB) Downloaded 232 times
ukalumni93
RE: Re: RE: 2010 Camaro SS L99 Kooks LT Header Tune
Headers are installed and I have driven it 65 miles. As predicted, the CEL is on. I am going to start data logging tomorrow in order to adjust the LTFT. Thanks to Diablo and this forum all this is actually enjoyable instead of overwhelming. Once the CEL is tuned out all apprehensions will be gone. Thanks again.
ukalumni93 - PM sent...
ukalumni93
06MonteSS.... you are the man!! Thanks for your expertise. Car is running smooth, strong and efficient (averaged 24 mpg on long road trip that took me on both interstate and city roads). I was very impressed with the combination of Airaid CAI, Kooks LT headers, HF Cats, recently installed 3in Magnaflow Competition Cat Back and your tune on my track runs tonight. 8.0 1/8th time.
To anyone looking at upgrading and in need of a custom tune.... 06MonteSS is priced just right to get the most out of the upgrades.
NICE man!! good to hear!!
and thanks!!!
and thanks!!!
Re: RE: Re: RE: 2010 Camaro SS L99 Kooks LT Header Tune
What codes were you popping up out of curiosity?ukalumni93 wrote:Headers are installed and I have driven it 65 miles. As predicted, the CEL is on. I am going to start data logging tomorrow in order to adjust the LTFT. Thanks to Diablo and this forum all this is actually enjoyable instead of overwhelming. Once the CEL is tuned out all apprehensions will be gone. Thanks again.
RE: Re: RE: Re: RE: 2010 Camaro SS L99 Kooks LT Header Tune
Most likely P1133 and P1153
