Ford Lightning shift issues with overdrive button on
robbydiesel
this is a u7000 tuner #158 for a 99 Ford Lightning. truck runs fine and shifts fine with overdrive button OFF. when you turn overdrive ON, it shifts too soon and then kicks down like it is confused at wot. it does this on the canned tunes as well as the custom tune. it never did this with my previous Diablo chip. what would the overdrive button have to do with this shifting issue? thanks.
RE: Ford Lightning shift issues with overdrive button on
what is the revision of the Predator?
Can you also post the calibration ID too please?
robbydiesel
hey Mike. the revision is 9r01 and the calibration id is cux1. this is weird because it doesnt do it stock or with my chip. only with the predator on any tune. thanks for your help.
Please go to options/troubleshooting/show calid and tell me what it shows...
robbydiesel
mrad2k3 is the cal id. i have also pinpointed the problem to the part throttle shifting firmness adjustment in the modify parameters section. if i leave the setting stock, all is good. if i try to firm it up any, transmission goes crazy with the od button on. what would cause this? too much pressure maybe. thanks.
robbydiesel
robby, do you have the cables to export files? If you could export a copy of the file with issues I can take a look at it.
robbydiesel
hey, here is a copy of the custom tune that i run. it also has this shifting issue on the diablo canned tunes as well. like i said, it runs great as long as part throttle shift pressure is not raised.
could a line mod valve cause this?
- cux1srjones.frg
- jlp custom tune
- (224.13 KiB) Downloaded 316 times
Do you have a 3.73 in the truck? That is what was in that tune. I left it in there but made a few tweaks, give it a shot...
- cux1srjones_diablo.frg
- (224.13 KiB) Downloaded 284 times
robbydiesel
