TIRE SIZE
General Trinity Support
jsracer
TIRE SIZE
Post by jsracer »
On the Trinity where do I navigate to change the tire size?
RE: TIRE SIZE
What vehicle?
jsracer
RE: TIRE SIZE
Post by jsracer »
06 mustang
RE: TIRE SIZE
After you select the tune, choose modify tune, modify parameters then goto axle ratio.
jsracer
RE: TIRE SIZE
Post by jsracer »
mikel wrote:After you select the tune, choose modify tune, modify parameters then goto axle ratio.
I made it to that point and all I see gear ratio and Tire Revs.
Is there a formula I need to use?
jsracer
RE: TIRE SIZE
Post by jsracer »
I still can't find tire size on the Trinity, even though it states it in the manual.
What's up?
Vas@Diablosport
RE: TIRE SIZE
Post by Vas@Diablosport »
For tire revs per mile, measure your tires from the ground up, and divide that number in inches into 20168.
for example; 28 inch tires = 20168 divided by 28 = 720 revs per mile
i hope this helps
No, i don't work here.
jsracer
RE: TIRE SIZE
Post by jsracer »
I'll try that, but why does it state I can change the tire size yet I can't find this
Return to “General Trinity”
