OIL TEMP is not on PID list - Trinity - R/T Challenger 09
FrankOrange
Post by FrankOrange »
Hemi 5.7 (u7135) - R/T Challenger 09
Both version "v.1r07" and "v.1r07a" for my Trinity fail to show the PID option of OIL TEMP in Cooling menu [or in any other menu].
My EVIC display shows this data so the car has the sensor for this.
Is there any way to access this data and monitor it on Trinity?
jimb
RE: OIL TEMP is not on PID list - Trinity - R/T Challenger 0
Post by jimb »
Look in the J1850 Protocol Group.
FrankOrange
I am not sure where to find that J1850 Protocol Group.
Here is my PID list.
Cooling
-amb temp (f)
-amb temp ave (f)
-amb temp V (volts)
-cat temp (f)
-ECT (f)
-ECT V (V)
-exh temp (f)
-in man air temp (f)
-in man gas temp
Cylinder
-tcyl ve mod (mult)
Electrical
-batt v (volts)
-bat v filt (volts)
-bat v scaled (volts)
-O2S 11 def goal v (volts)
-O2S 12 goal v (volts)
-O2S 21 def goal v (volts)
-O2S 22 goal v (volts)
-oil press v (volts)
-tps 1 min v (volts)
-tps 1 v (volts)
-tps 2 min v (volts)
-tps 2 v (volts)
Emissions
-egr exh temp (f)
-egr flow (g/s)
-egr mass flow (g/s)
-egr pratio (pratio)
-egr sonic flow (g/s)
-exh press (kpa)
-in man egr mass (g)
Engine
-engine runtime
-oil press (kpa)
Ignition
-base spark (deg)
-spark adv 1 (deg)
Intake
-O2 htr sns v (volts)
-O2 htr 11 ref v (volts)
-O2 htr 11 sns v (volts)
-O2 htr 11 temp
-O2 htr 12 ref v
-O2 htr 21 ref v
-O2 htr 21 sns v
-O2 htr 21 temp
-baro (in Hg)
-gas mass in man
-intk temp
-intk temp V
-MAF
-MAP
-O2S 11 goal v (volts)
-O2S 11 sns v (volts)
-O2S 21 goal v (volts)
-O2S 21 sns v (volts)
Miscellaneous
-1/1 long term adap (%)
-1/1 short term adap (%)
-2/1 long term adap (%)
-2/1 short term adap (%)
-acc airport mass flow
-adap 11 fact
-adap 21 fact
-avg total working pw
-baro mult
-baro OBDII
-base ve bank 1
-base ve bank 2
-cmv OBDII v
-desired fa cyl 1 far
-gas flow map
-map OBDII
-map v
-map vac
-misfire cnt
-O2S 12 adap
-O2S 22 adap
-open loop fa far
-p-rat map baro
-pcv mass flow
-phi adap
-phi mult
-port prg flow
-port prg flow bank1
-port prg flow bank2
-prg vac
-read map kpa
-read tip kpa
-tcyl
-tot port mass flow scaled
-tot port plg flow
-total ve bank 1 (%/100)
-total ve bank 2 (%/100)
-veh spd mphx2 (mph)
-veh spd x64 (mph)
Misfire
-knk fuel retard (deg)
-knk lt retard (deg)
-knk sns 1v (mv)
-knk sns 2v (mv)
-knk st retard (deg)
Peformance
-eng rpm (rpm)
-rpm (rpm)
-veh speed (mph)
Throttle
-base idle spd (rpm)
-thr blade (%)
-thr pos % (%)
Analog inputs (for plug in sensors)
-analog input 1 volts (v)
-analog input 2 volts (v)
-battery voltage (v)
-peak-to-peak voltage (v)
-Trinity temp (c)
-Diablo egt (f)
-Diablo xpuck (%)
Synthesized
-boost (kpa)
...and here is my tool info:
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM9 at 57600 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Trinity'.
Serial number = '6JTJAD5-1'.
Part number = 'u7135'.
CROM version = 'u7135-1r07a 02/18/2010 02:08:05 PM boot3'.
Vehicle VIN = '*****************'.
Vehicle Calibration = '05187912AF'.
Origional backup SAVED.
Tool is Married TRUE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are SUPPORTED.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is SUPPORTED.
Tool SUPPORTS multiple ECUs.
Config does NOT indicate multiple ECUs.
Tool reports 1 ECUs.
I am still looking for OIL TEMP option.
FGorhau
Post by FGorhau »
FrankOrange wrote:I am not sure where to find that J1850 Protocol Group.
You and me both, brother! If it's not in the list, perhaps Diablosport can do an incremental update to make it available? If I can see it in the EVIC, it's got to be available somewhere in the ECU...
jimb
Post by jimb »
OK. I see what happened. J1850 group only shows up with a 05 SRT8 ECU. Same tool; but for a different ECU family.
There is a PID called "OIL TEMP Calc" in Cooling group in Trinity that is part of 07 thru 09 ECU family. I'll need to investigate why it's not showing up.
440-6GTX
Re: OIL TEMP is not on PID list - Trinity - R/T Challenger 0
Post by 440-6GTX »
I noticed the same thing with my 2010 Hemi Charger Police Model....
FrankOrange wrote:Hemi 5.7 (u7135) - R/T Challenger 09
FrankOrange
It seems like there is no quick fix for this.
I was wondering ...replacement could solve this?
Is it possible that a Trinity behaves differently than the other one on the same car? or this issue comes from my car and replacement won't help?
Any Trinity will be the same.
FrankOrange
Any thought on this subject? This issue exists for months.
I've been away...have I missed the solution somewhere :) ?
FGorhau
Post by FGorhau »
Thought this thread was dead, did you!?
I was hoping the new mega-update would have included an oil temp PID... still no luck.
I like the new look, and the scalable gauges, but WHERE'S THE OIL TEMP?
You bet your ass it's got a HEMI!
