Does this work with the 2010 2500HD 6.0L?
orspg
Post by orspg »
I am expecting my new t1000 tuner tomorrow. Ordered it week ago for my 2010 2500 HD 6.0L Silverado. I want to make sure (since I was told by other sites it'll work) it will work on the 2500 HD submodel.
orspg
RE: Does this work with the 2010 2500HD 6.0L?
Post by orspg »
The Mods on my 2500 HD are Flowmaster 3.5 inch exhaust, Airaid CAI and Throttlebody spacer, and Jet Mass air sensor, if that info helps. Also is the a CAI setting for the 2500 HD 6.0L? What else should I look out for? I am very excitied about installing this onto the my truck! Thanks!
2015 Silverado 3500 HD Crewcab LTZ, Dually, Duramax/Allison 4X4
just answered your other post over here:
http://diablosport.com/index.php?name=P ... ic&t=23158
and to reiterate... get rid of that jet maf sensor and put the stock on back on!! but, you'll see that in my reply in your other thread :)
orspg
Post by orspg »
Thanks, so it will work with the 2500 HD then?? YAHOO!!!!!!! and is there any way possible that the jet can be utilized or is it just hopeless?
yes it will work with your truck...
dump the jet...
orspg
Post by orspg »
Again, thank You so very much for the great advice!
orspg
Post by orspg »
06MonteSS (Lew), Is there a process to log the Silverado like you instructed me to do with my Escalade? Thanks in advance!!
orspg
Post by orspg »
Sorry, Andrew (06MonteSS)
I don't know what happened. Your name changed!
Dom
huh?? who's Andrew?? I am Lew... had it right the first time :lol:
yes, the logging process is the same for both vehicles...
orspg
Post by orspg »
Lew, Just got the Trinity, doesn't list my 2010 2500 HD also I think I messed up, I plugged it in before indtalling the cd so I don't think i installed the drivers, but the connection test says its ok??
orspg
Post by orspg »
Lew, pluged it in and it says it's not campatible with my truck. You said in another post to use 2009 and I did that and still nada! It told me to download the stock file and then call the "number". You guys are closed and I'm in California, so what do i do now? ;-( I haven't tried the escalde yet, since i really want to get his fugured out.
orspg
Post by orspg »
ok got the com ports, drivers, and such figured out. All is working great but now I don't have a the diablo icon anymore. I uploaded the stock file like the system said and now I'm stuck. What's the next step? Return this thing because it doesn't work? Help me out here. I thought this would be easier than this, I'm sorry. I'm using windows 7 by the way
what revision is on the trinity???
go to options > show information and it will tell you...
you probably have to update the trinity to the latest updates... which you can get from here:
http://diablosport.com/index.php?module ... ay&pid=153
you'd want to make sure it's on the 1r07 base revision... if it's not on 1r07 already, you'll want to download and install the revision update for "trinity_1r07.crom"
and then you also have to install the incremental update: trinity_u7194-1r07a_update.crom
and you need to use the DSDownloader program to do the revision updates...
Return to “Trinity GM Gas”
