Template for Box Code YAZ4 - Cal ID CFAK8E4 (or CFAK8)
illinoisdyno
Post by illinoisdyno »
Does anyone have a CMR Tuning Template (.tpl) file for a 1996 F-150 5.0L Box Code "YAZ4"?
I have a good .frg file, but no way to tune it without the template file for this application....
Any help would be greatly appreciated.
Thanks for your time!
Tom
kmac1
Post by kmac1 »
Try this template. Your calid is cfak8 but my template for that calid is showing all 0's in the proper template. Make sure you manually select this template and everything should look fine because all the stuff is in the same location.
cfak7.tpl
(2.53 KiB) Downloaded 378 times
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
illinoisdyno
Thank you, VERY MUCH, Kevin!
I have manually entered this as a template, along with a base YAZ4 tune, and it works! Only concern is that there are very few parameters available, but at least its a start!
Thanks, again, for your efforts!
Tom
