05 gt air raid tune problem
i have a 05 gt with a air raid cold air intake and when i install the tune for the air raid it has a very rough idle when i start it then i will sputter and die plz help
RE: 05 gt air raid tune problem
Have you removed the venturi from the intake?
i am sorry what is that?
the airaid intake has a insert that needs to be removed for use with the tune.
can u point me in the right direction where this is located and what i would look like? i have never even heard of this part that would have to be removed
It is referred to as I think the MVT insert or something along those lines, and would be located before the MAF.
ok i will see if i can locate this and will let u know thanks for all ur help mike
one more question...so this insert do i just take it out? or do i have to buy something else to go in its place?
mike i figured it out..u take out the MAF and it slips out thanks again for all the help..going to take it to the track tonight to see how it does
It should be a whole new animal!
i also have an airaid on a 05gt is there a spasific tune for the airaid if so were can i get it
what octane do u run in your gt ?
u would run the regular airaid tune with 91 ocatane i run 93+ octane so i use the 93 octane with agressive shifts
