Does installing your predator effect your readiness on emissions?
I drove 170 plus miles still to fail.
Reinstalled my factory tune. Drove 60 more miles and still failed.
Evap - Not Ready
Both O2 - Not Ready
Total of 3 not ready on test.
Can the Predator cause your computer to not read these perameters after using it?
There are no codes thrown. Car runs fine.
It is even baffling the state inspector.
State Inspection - Failed - Evap & O2 Not Ready - HELP!
All of the monitors require a set of conditions to be met before they run. When you switch tunes with the Predator, the monitors are all reset. To the best of my knowledge, they should all run regardless of the tune installed by the Predator. I have been back and forth between the stock and the 87 octane tunes on my Silverado and I have had no problems with my emission monitors. They all run eventually.
The EVAP is one of the worst and generally runs last because one of the other monitors must be completed before it runs. That EVAP monitor has a miriad of conditions to meet. Much more than the others such as the tank has to be between 15% and 85% of capacity, the IAT has to be within a certain range, and etc. etc. Usually most will run if you complete a specific drive cycle, but the even then, the EVAP monitor might not run.
You just have to keep driving it. They will run eventually and you can't predict when they all will run. Generally, a desirable drive cycle that would possibly make them run includes accelerating to highway speed from a 10 to 25 mph speed, then driving at a constant highway speed (55 mph) for five to ten minutes, a deceleration (no braking) down to under 20 mph, cruising at 20 to 25 mph for few minutes, and then an acceleration back up to highway speed. In other words, drive around town and on the highway a few times.
I hope this helps with your questions. Maybe others can provide other insights/corrections to my comments.
2000 Chevy Silverado 1500 Z71 4WD ECSB 5.3L
U7198 ver 9r17
Diablew Tuned
K&N CAI
Corvette Servo
U7198 ver 9r17
Diablew Tuned
K&N CAI
Corvette Servo
