Can you check my diablo tune?
Could you please check the diablo tune that is on my car which i will include, i was having a problem with my car overheating and was told it was due to the tune that is on my vehicle, could you please check the fan settings that are set on it and tell me if everything looks good. Thanks in advance.
- dave_vortec_93pump-lasttune.frg
- this is tune on vehicle
- (458.98 KiB) Downloaded 209 times
RE: Can you check my diablo tune?
Did you make any changes to the fan settings, or did you leave them as we set them?
it was left the way you set them
The fans are coming on alot earlier than stock and are not causing the car to overheat. Get a second opinion.
http://www.tpctuning.com
one other ? when the fans do come on it seems like they run constant, could the fan motor be overheating and shutting down from the temps in the tune causing them to come on earlier?
That is highly unlikely. Majority of custom tunes lower fan temps 20-30 degrees from stock. Been that way for the last 8-10 years, still have cars running fine with the fans like that. Shouldnt be a problem at all.
