2010 mustang predator firmshift tune
Dlira4213
Post by Dlira4213 »
Yeah I have a new mustang gt it's auto, am I not supposed to be able to choose the firm shift tune since it is auto... Each time I try it says the tune was not able to be installed or whatevr then it makes me reboot and put in the original backup which takes long first off then I trying putting in the firmshift then it has to make a back up shhh it's so annoying idk anyway long story short can I or can I not put firmshift on my auto mustang if I can't y not
RE: 2010 mustang predator firmshift tune
what is the revision on this predator?
Dlira4213
Post by Dlira4213 »
how do i check the revision
Dlira4213
Post by Dlira4213 »
revision .9r02
So it will load other tunes?
Go to options/troubleshooting/show calid and post that please.
Dlira4213
Post by Dlira4213 »
yeah it will load other tunes but when i try loading the firm shift it fails to do so
Dlira4213
Post by Dlira4213 »
calid:FEBF1AC
kmac1
Post by kmac1 »
When you install the tune do you have any of the adjustable parameters changed or are they left stock? I just tried it on a bench computer and it was successful, same revision and calid. Do you have any aftermarket or non-stock electronics in the car? If so, disconnect power to them and make sure everything in the car powers down when you turn the key off during key cycles. There may be some residual power somewhere that the Predator doesn't like.
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
Dlira4213
Post by Dlira4213 »
and it should work even though the car is auto..??
Yes...
Dlira4213
Post by Dlira4213 »
idk if it makes a difference but when i tried putting the tune i tried changing the speed limiter and the rev limiter and traction control does that make a difference wether it would let me install the tune or not
Dlira4213
Post by Dlira4213 »
or should i just install the tune without adjusting the parameters
Dlira4213
Post by Dlira4213 »
idk if it makes a difference but when i tried putting the tune i tried changing the speed limiter and the rev limiter and traction control does that make a difference wether it would let me install the tune or not or should i just install the tune without adjusting the parameters
Return to “Predator Ford Gas”
