Hi all...Data analysis please?
Michael_Js
Post by Michael_Js »
Hi...Recently got my Trinity back from repair, installed the Octane 91 tune, did 1 data log, adjusted the LR Fuel trim +1%, did another log (after driving a while). Second analysis shows no further changes - also turned off CAGS
This is all for a 2010 Camaro SS with ADM Race intake, JBA headers, & Zoomers 3" Cat-Back exhaust. I know I can get more out of her with a custom tune, but this is my first ever experience with tuning - so please keep the flames on low - ;)
Ok, I can read some of the analysis data, but other than knowing to keep the LR Fuel trims in a certain range, I have NO idea if any of the rest of the data is in a valid, sub-optimum, or optimum range.
Can someone look at the attached data log and give me some input please?
THANKS!
Michael J.
2010 Camaro Black 2SS/RS; 6M; IOM, GFX, sunroof; 'MY MSCLE'; Diablo Trinity Tuner - NEW user
Ill_Born_SS
RE: Hi all...Data analysis please?
Post by Ill_Born_SS »
You got your trims right where you want them. Add the CAT Temps (COT)to your next log and go for the WOT run (safely), get your PE fueling and Total Knock/knock retard to an ideal setting. Adjustments made here are instant, no need for any relearn.
" Just Friggin Wicked"
Now with TCM support...
Michael_Js
Thanks! I need to figure out where to do WOTs ;)
Michael_Js
Quick question: what is needed for a WOT log? Meaning, how long at WOT? Run through the gears? Stay in a particular gear at WOT - well, before rev limiter cuts out.. ;) Never done one before.
Thanks!
Michael J.
Michael_Js
I forgot to mention that I did a quick WOT using the GM 6K shift log file. It was just 1st to 2nd. Not sure if this has any useful data since I had no idea what I needed to collect...here's the CSV file
Ill_Born_SS
go -2 high rpm range for power enrichment and do another like that , for longer if you can and try from dead stop if possible.
(be safe)
Ps: see if you have 2 or 3 PE fuel enrichment adjustments.
Michael_Js
Thanks, I'll try that ;)
Oh, BTW, that short run was from a dead stop ;)
Michael_Js
Hey Lew, sent you the tunes & data files for a custom tune ;) let me know when you get it!
Happy Father's Day to all!
yep, got it... was away for the weekend... will check things out tonight after work...
I gotta big backlog to get through now :lol:
Michael_Js
I appreciate it Lew! It was just a check, not a rush ;)
Got it this evening! Already programmed in The Beast. Now to test drive and report ;)
Thanks!
hahaha... nice man!!!
Return to “Trinity GM Gas”
