question on the cummins
bones
Post by bones »
could you in the programming remove the P R N D 2 1 that appears in the gear selecter area,i believe this may eliminate tq management
RE: question on the cummins
To remove TM you just need to disable it in the tool. Not sure how the gear selector would be an issue.
Mike
ropnjessi
Post by ropnjessi »
I think he could be refering to the Bully Dog, because when you turn off the TM for the high end P R N D 2 1 dissappears whereas on the low end power only they will still display....
johan
Post by johan »
We have not had a chance to play around with the torque management in the Dodges yet. It might be a later venture as we need to jump on the 6.7L here shortly.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Return to “Predator Ford Gas”
