DPF DELETE????
DPF DELETE????
Will you ever be doing dpf deletes? I have a wrecker service in Houston with about 15 07-2010 lmm's and the older trucks are starting to have issues with the dpf's. I really don't want to go with quadzilla because I had always had good luck with the predator but I need a programmer that will allow me to disable the regeneration and remove the filter on those trucks.
RE: DPF DELETE????
Have you looked into any of the plug in devices that delete it?
