I have a U7186 from my 2007 LBZ that worked great. I have since traded for a 2010 LMM.
Will there be updates that will allow me to use my 2007 U7186 with my new 2010 LMM? Also, if there are updates, will they include the capability to delete the DPF and defeat the codes?
When will the 2010 LMM U7186 updates be available?
RE: When will the 2010 LMM U7186 updates be available?
We will not be doing DPF deletes, but we will be adding support for the 2010 models in the near future.
Thanks Mike,
What is "near future"...1 week, 1 month? The mileage and sluggishness is killing me, I need the Predator back!
Re: RE: When will the 2010 LMM U7186 updates be available?
Will you ever be doing dpf deletes? I have a wrecker service in Houston with about 15 07-2010 lmm's and the older trucks are starting to have issues with the dpf's. I really don't want to go with quadzilla because I had always had good luck with the predator but I need a programmer that will allow me to disable the regeneration and remove the filter on those trucks.mikel wrote:We will not be doing DPF deletes, but we will be adding support for the 2010 models in the near future.
I relly hate to hear that, but it is out of our hands.j_b_5_2 wrote:Will you ever be doing dpf deletes? I have a wrecker service in Houston with about 15 07-2010 lmm's and the older trucks are starting to have issues with the dpf's. I really don't want to go with quadzilla because I had always had good luck with the predator but I need a programmer that will allow me to disable the regeneration and remove the filter on those trucks.mikel wrote:We will not be doing DPF deletes, but we will be adding support for the 2010 models in the near future.
The way the EPA talks about it, you'd think all the companies offering dpf deletes would havebeen shut down by now....sucks being the good guy sometimes.
