Can I run my D7159 with the Quadzilla Mileage Max? How about the D7159 with
a boost fooler? 2006 Dodge Ram 2500 w/ Cummins TD.
thank you
D7159 and Mileage Max?
RE: D7159 and Mileage Max?
Boost fooler, yes, not so sure bout the mileage thing, what is it exactly?
Is it OBDII based, or plugs in under the hood?
Its an underhood plug and play module. Connects between MAP sensor, fuel rail pressure, and coolant temp sensor. Advertises
8-12% mileage increases. Quadzilla Max Mileage Module. So it would be inline with power puck just like boost fooler would be.
No, I dont know if thats a good idea.
So if I install my Quadzilla boost fooler ahead of my D7159 at the MAP sensor will everything function
like it should? ie: lowering my EGT's while my puck does its thing?
yes...
