DataViewer Release Downloads
Locked
johnc
Post by johnc »
DataViewer 3.x is available for download at the following link(s):
http://www.diablosport.com/CMR/software ... .3.0.8.exe
Any bugs, comments, or suggestions can be posted here in the forum.
Release Notes:
DataViewer 3.x release notes
3.3.0.7
- Support for new Trinity converged tools.
- Default Gauge selection
- Internet Update notifications
3.3.0.6
- Support for slp6000. Works same as u7194
3.3.0.5
- support for new Trinity planned tools: {ford can gas, ford can diesel, gm can gas}
- Handle empty analog configuration Name and Units attributes from older Trinity CROMS log playback.
(this was causing log fatal errors and progress bar issues during playback.)
- handle Mult ECU info in Show->Vehicle Info
- PID Tree View bug
3.3.0.4
- re-enable DMR support for F150 u7151 (Trinity)
- remember last folder used when saving or playback of log files.
- fix 7194 E40 Invert
3.3.0.3 - Beta
- New GM Gas PIDs for 7194
- New Ford PIDs for 7151
- Include External/Analog inputs configuration in DataViewer log files for proper playback when not connected to a Trinity
3.3.0.2 - Beta
- Include support for Cyl #1 - Cyl #8 Balance Rate PIDs (U7186).
3.3.0.1 - Beta
- Introduces External Input Analog live streaming and logging. Allows download and playback of log files (containing Analog inputs) from Trinity.
3.2.0.7 - Re-release using VS-2005
3.2.0.6 - 3.2.0.5 - ?
3.2.0.4 - New DMRs and Trinity Analog Data Fix
3.2.0.0 - New DMRs for FSAD0.
3.1.9.9 - GM CAN support for Trinity
3.1.9.8 - Bug Fixes, PID additions, improved communications layer.
3.1.9.6 - Bug Fixes
3.1.9.5 - Expanded Trinity support.
- Analog inputs within downloaded logs.
3.1.8.8 - More Trinity/Cummins support.
- Tweaked Ford DMRs.
- Temperature converter fix.
3.1.8.5 - Trinity and Cummins support.
3.1.8.4 - Fix to default data files location.
3.1.8.3 - Fix to live data streaming for some GM vehicles.
3.1.8.2 - Additional Predator part numbers, QBIC support.
3.1.7.4/5 - Additional part numbers for GM Class 2.
- Tooltips on the parameter tree for alternate descriptions (acronyms).
3.1.7.3 - Additional parameters for GM Class 2.
3.1.7.2 - Fix to log download unable to open some logs.
3.1.7.1 - Support for new GM predators.
- Log download and viewer support for CMR_DAT predators.
3.1.6.8 - Another bug fix (tool version outdated).
3.1.6.7 - Bug fix and data tweaks.
3.1.6.3 - Fixed Windows 98 compatibility broken in 3.1.5.12.
3.1.6.2 - Database adjustments to parameters for various vehicles.
- Communications fixes to allow operation on slower computers.
- Upped thread priorities for Vista to prevent timeouts.
3.1.5.12 - Many fixes for Windows Vista
- Using common application data area for database file and runtime logs.
- Moved data files (logs, vehicles, dashboards) under My Documents.
3.1.5.10 - Workaround to corrupt downloaded log files from U7135.
- Enabled DLL install for Vista to account for missing MFC dlls.
- Quicker thread exit to reduce "app already running" messages on restart.
- Various parameter database additions and tweaks.
- Fixed missing bit field descriptions for some parameters.
- Support for ford and gm diesel parameters.
3.1.5.5 - Fix to missing vehicle identification in downloaded logs.
3.1.5.4 - Workaround fix for 7135 downloads.
3.1.5.3 - Communications tweaks
- Help file additions
- Fix to vehicle identification upon open log
Screen Shot
johnc
RE: DataViewer Release Downloads
Post by johnc »
Bump for release 3.2.0.0
johnc <at> diablosport.com
jimb
Post by jimb »
Update for 3.3.0.2
jimb
Post by jimb »
Update for 3.3.0.3
jimb
Post by jimb »
Update release notes for 3.3.0.5
Locked
Return to “DataViewer/DV2”
