U7134, Dataviewer not saving entire recorded log
jsachnet
Post by jsachnet »
u7134, 2004 SRT4, 9r19, Dataviewer v3.3.0.5
Dataviewer is only saving logs for about 15-30 seconds of each run, then it stops saving. The live view still works and gives no indication that it is not recording nor does it show any faults or errors. I logged multiple times for over 15 minutes and got ~30seconds of saved data in each log.
A search for this issue revealed a similiar case for a different model predator here http://diablosport.com/index.php?name=P ... highlight=
runtime.txt
(12.92 KiB) Downloaded 229 times
jimb
RE: U7134, Dataviewer not saving entire recorded log
Post by jimb »
I assume the older version of DV (3.2.0.7) is also giving you problems?
Also, are you using USB-Serial converter cable and (Prolific) driver? Or, RS-232 9pin cable with your PC/Laptop?
jsachnet
Post by jsachnet »
Older version of dataviewer gave the same problem so I updated, I am not sure what version it was before. I am using the Prolific usb-serial cable and drivers on windows xp sp3.
jimb
Post by jimb »
This is an issue with the 9r19 version of u7134 Predator CROM; Not DV. A new release of u7134 is coming out shortly.
UPDATE: Live streaming issue is fixed in 9r20
Return to “DataViewer/DV2”
