WOT Logging
edv2122
WOT Logging
Post by edv2122 »
When you are looking at values during WOT runs is there a preferrable gear to watch and log and make adjustments based off that gear WOT run?
For instance my AFR seems to fatten up a bit in 3rd vs 1st and 2nd at WOT.
Gear:
U1974
06 Vette
RE: WOT Logging
you wanna do a WOT run going through all the gears, so you hit all the rpm ranges....
you don't wanna be in a high gear and just mash it, cuz that'll give ya KR and won't give ya a true AFR reading.
so start from the lowest gear ya can, and go WOT through all the gears... as long as you have enough room... gotta be safe!!
