2006 silverado rev-limit
manny
Post by manny »
I have a 2006 silverado 4.8l with true flow intake and predator U-7192. While torque braking the engine RPM only reaches 1500rpm with the diablo tune it reaches 1700rpm. Is there any way to resolve this issue to raise the RPM?
RE: 2006 silverado rev-limit
You are seeing the max stall speed of the converter, it is not a limiter.
To make it hold a higher RPM on the brake, you would need a looser converter.
