05' Dodge Ram - u7137-9r06 - No more Trans control????
white_lightning
Post by white_lightning »
mikel wrote:good news.
yes. good news indeed! I am stoked about being able to start tuning my tranny.
Stu sent me another TCM file with more features and it loaded too. looks like we (You, Stu & Me) got how to load a CMR TCM file in an '05 Hemi Ram figured out.
can you help Stu understand what some the stuff in the tranny folders is? He was muttering about Newton-meters of torque and not knowing what the different settings would do.
I apologize for getting cranky.
motorscooter
Post by motorscooter »
white_lightning wrote:
GLP77 wrote:Here is the 9t08a crom that I have. It still does not recognize my TCM. Could you let me know if it works for you?
thanks! I hope to have time to try it tonight.
I have trans control now with 9t07d, also had it with a couple other Croms.
what are your calibration #'s?
mine are:
PCM: 56028958AI
TCM: 05094258AD
edit:
looked up the page and saw your calids:
2005 ram 1500 hemi
PCM 56028958AI
TCM 05094258AC
your PCM is same as mine, TCM looks like it could be a late '04. I have heard that early '05's can have late '04 TCMs.
all the good stuff.
motorscooter
No iit looks like an 05 David, the only ones ive found for 04 are 56028810 AE and AD
all the good stuff.
the-drew
Post by the-drew »
white_lightning wrote:you're welcome! bummer that the new Crom didn't fix your problem.
Yes it is. especially since I need to change tire size and a big part of the reason i bought the predator was so i could adjust trans. I have a (stupid?) question. How can i figure out what my tcm calid is if it won't show on the predator?
white_lightning
motorscooter wrote:No iit looks like an 05 David, the only ones ive found for 04 are 56028810 AE and AD
thanks Bob! how ya been, man? same stuff, different day here.
white_lightning
worst case scenario, a Dodge dealer can change tire size.
good question, only way to find stuff out is ask! Dodge dealer can read TCM calid too. I think it is written on the sticker on the ECU too, but I'm not sure.
motorscooter
same thing here. if it slows down sometime . i'll pm you about meeting up on a saturday at gas city.
all the good stuff.
white_lightning
motorscooter wrote: same thing here. if it slows down sometime . i'll pm you about meeting up on a saturday at gas city.
sounds good! I've though about meeting @ Gas City several times, but haven't had the time yet either, dammit. I think I still have your ph#.
gergregg
Post by gergregg »
9t08a still hasn't fixed my problem. When loading a custom tune the transmission parameters show up during the initial install under modify tune. However, when the tune is loading it only does the PCM. After going back in to custom tunes > modify tune the transmission/pcm selection is no longer there and it only shows pcm parameters.
Still no transmission control.
gergregg
Post by gergregg »
Upon further investigation the transmission parameter selection came back, but with my custom tune it will not program the TCM if I modify tune. On the canned tunes it worked fine. It showed both PCM and TCM being programed.
Do we need a custom TCM tune or should we be able to modify the the current custom tune?
white_lightning
gergregg wrote:Upon further investigation the transmission parameter selection came back, but with my custom tune it will not program the TCM if I modify tune. On the canned tunes it worked fine. It showed both PCM and TCM being programed.
load a canned tune with the shift adjustments, then load the custom PCM tune. that will give you the altered shifts.
gergregg
Post by gergregg »
I will have to try that this weekend. Thanks
white_lightning
you're welcome! hope it works right for you.
Diablo Dodge CMR Tuner
Cell Phone#: (520) 508-5320
My Ride:
2005 Ram QC 1500, APS converter, 210/214 112 LSA cam, LT headers, True Duals, 4.56 gears, 180* T-Stat and some other mods. Tuned by Me.
geoffcoop
Re: 05' Dodge Ram - u7137-9r06 - No more Trans control????
Post by geoffcoop »
At my wits end with this update crap :blowup: Completes stage 1, and then reads" The application is missing or corrupt." HELP!!! :lamer:
which crom are you trying to load?
